Manufacturer: Kitchenaide
Type of Appliance: REFRIGERATOR
Model Number: KSSC42QMS/03
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Happy New Year, I'm in search for the tech sheet for this model. Customer stated the icemaker doesn't work. Went to diagnose it and notice the icemaker sensor wasn't solid red when I held it down, so I replaced it. I tested the voltage at the icemaker terminal and I'm getting 104vac which is strange because I'm getting 124vac at the connector plug. The only other thing I can think of is check the water valve because when I used the jumper to call for water nothing happened. Any help would be greatly appreciated
  • Replies 1
  • Captain Dunsel
  • onedoorappliancerepair
Uses the same tech sheet and wiring diagram as this one!
Uses this ice maker Service Sheet 2306424 Only!!!!
