Sensors seem to be faulty.  It started w/machine putting in water for 10 secs then full stop.  I now unplug machine-let stand .5 hr -plug in + reset all dials.  Sometimes it goes full cycle properly.  But I have to reset all the time + seems to be worsening.  How can this be fixed?
In the console there should be a tech sheet. Use the tech sheet to pull error codes. Let us know what you find out. Also there is a service flash about casting flashing in the pressure done used for water level sensing. Follow the rubber hose from the control module down to the port on the side of the tub. Remove the hose and look in the nipple, it should be clear with no obstructions.
