GE Refrigerator MDL # GSH25JFXJ WW
My Refrigerator has quit cooling.  I would very much appreciate help trouble shooting the problem so as to decide whether I can make the repairs or have to replace it.
Thanks for any and all help.
You not giving us enough info,  is it not cooling at all?  Is the lights in the unit working ? Are you hearing anything? Is there frost on the freezer back wall,  is the compresser running?  Is it warm?
Give us the model number and info stated above and we may be able to help
Thank you both for your response.  I think I found the problem.  The fan in the freezer compartment isn't working so the refrigerated air isn't making its way to the refrigerator side or the upper section of the freezer.   I was not aware of the fan until I emptied the freezer.
Glad to hear! Hope you get up and running quickly. Thanks for the update.
Now you need to determine if the fan motor is bad or it’s source of power is bad.  This is done by checking for voltage at fan or from source.
  • 2 weeks later...
16345Ed
  • Sensei
  • It was definitely the motor was bad.  I replaced it (knock on wood) it is working fine.
  • Thank you to everyone that offered help and guidance.
