    • 27 September 2025 02:00 PM Until 03:00 PM
      When: Saturday, September 27 @10:00 AM Eastern Time.
GE washer WSXH208A1WW timer will not advance.
The timer will not advance on its own but all functions work when timer is manually advanced. I replaced the timer but new timer will not advance either so I checked power to timer motor it has 120 volts to it. Any idea of what to do next?
  • herfdog
  • suampman
  • evaappliance
if you have 120 coming to the timer motor and it doesn't advance , you have a bad new timer
Thanks, that's what I thought but wanted to double check with a professional.
  • 2 weeks later...
Coming in a little late with this but I have seen plugged pressure switch hoses cause what appears to be a timer problem.
