Manufacturer: Bosch
Type of Appliance: Dishwasher
Model Number: shp865wd6n/10
no display when door closed
need manuel
  • Abraham6060
  • Captain Dunsel
You should be able to use this!
Thank you for the link basically after playing with the reset a few times I got it to reset but when the door is open I see the display in the button it was press gets highlighted by the LED and the door is closed that does not happen is the question if this is normal because usually you pushed it in floss you don’t see the top or you should be able to see the display on the door is closed?
