Door Hinge Replacement on Viking Range Model VGSC3666BSS
I need to  replace the oven door hinge on my Viking range.  I would appreciate any experience-based advice on parts sourcing and especially any potential issues in replacement.  Middleby-Viking doesn't even list this model in their online parts listing so I assume parts are not available from them anymore.
  • Replies 4
  • Rusty Wrench
  • ECtoFix
  • isaac
  • Terry Carmen
Well, I finally found the part on Middleby's website (not easy to navigate).  Still need any hints on actual replacement process.  Thanks in advance.
Its not to bad to replace but its not as easy to explain,  look at the new ones when you get then and take off the door,  it should be straight forward after that,
Will this video work for ya?
It should come off just like in the video above.
Also if you've never done one before, be really careful of the door. It's heavier than you're going to expect, but easy to damage and easy for it to damage you or the floor.
