Kenmore Elite 665.13183k800 Won't Start
The dish washer will not start, a while back I replaced the motor and the washer worked for while. Then we started getting 6 - 1 blink pattern. We would do a diag and it would work for a while. Now it will not start and when pressing the Start/Resume button it blinks three times then the light shuts off.
Looking for suggestions on how to diag the issue?
  • kbilbee
  • Vance R
6 and 1 blink is a communication error between wash motor or diverter motor.  3 blink wasn't listed but indicates board thinks the door is open. Check the door switches and wiring. The tech sheet should be in the toeplate area.
Thanks I forgot about the tech sheet in the toe plate. The tech sheet indicates the three blink on the start/pause is and a blinking clean LED indicates control detected motor and or heater problems.
