Hi there,
I have a Fisher and Paykel Elba OR61S2CAWW1. This is an example manual https://manualzz.com/doc/3152959/fisher-and-paykel-or61-user-s-manual
At the moment, the light will turn on, however the oven does not heat. The red indicator light also does not light up.
I previously had the same issue, however I was then alerted to the automatic cooking feature. I must have bumped it or something, as when I followed the instructions to put the oven back into manual mode, it worked.
Shortly after, the same issue has appeared, but I cannot fix it this time ensuring manual mode is set.
The steps I'm taking to ensure that it is in manual mode:
Cook time button turned anticlockwise to the stop logo (note, this does not seem to click into position)
^ white arrow at the hour hand. This clicks into position.
At this point when the oven is turned up to temperature, the light will come on, and no heat occurs, and no red indicator appears
https://ibb.co/bPXqXLG
https://ibb.co/bRXSzTh
The above images show the state of the function dials when the ovens light is on, but oven does not heat.
  • Replies 0
  • kmart
