Bosh Dish Washer
Gregg
Model number shu4302uc. This unit will not come out of the wash cycle.  If you turn it of and then back on right back to washing.  Tried disconnecting power, but went right back to washing.  Would this be the control board? Thanks Gregg
  • Replies 4
check the cntlbrd for a burnt solder joint. this is a regular problem with these.
I'd like to read your soldering pdf.  Am I simply redoing the solder on that point of the board? Thanks
Here y'go, Buddy-row (attachment). Yep, usually just re-making that burnt solder joint restores dishwasher bliss. Sometimes, though, that relay gets taken out so you gotta replace the whole board.
How_to_solder_1.pdf
