Electrolux LEH1642DSO washer won't spin on full load...
Eric Gunnerson
This is a stacked front-loading washer and dryer.
It's behaving strangely; if you do a full load of laundry, it will not spin during the spin cycle; it goes through the whole cycle but no spinning.
If you take that load of very wet laundry out and put it back in 1/3rd loads - or just run a small load instead of a full load - it works fine.
I've found a few examples of the wiring diagram online, but none of them are legible.
  • Replies 1
  • Josh Smith
  • Eric Gunnerson
If the load is Too large it may not be able to balance it out causing the no spin problem
