Manufacturer: Danby
Type of Appliance: Wine cooler
Model Number: DBC2760BLS-1
 I had to go out to get the mo#. The unit is built into a cabinet and the mo# was on the back. I got the mo#. their are two dbl. door units next to each other and the power cord runs back behind the other unit so I thought maybe I better have the tech info before I start tearing everything apart. What I did notice is the compressor running and very hot to the touch. The condenser fan was running and coil was very clean. Inside the unit the fan was running on both sides and where I could see the coil through the panel there was no frost. I'm thinking sealed system and am hoping the tech info will give me error codes or more info to verify the condition. I don't do sealed systems. This unit is from 2013 and seems like a lot of parts aren't avaliaable.
  • Replies 4
  • Son of Samurai
  • Captain Dunsel
  • AllStarBob
  • Vance R
I've not been able to find any info on this one, unfortunately.
@Vance R, @Captain Dunsel, or any of the other Brethren -- are you able to find anything for this one?
I got nothing on that one.
Same, no information
