Model #11020022013 Kenmore washer - completing cycle
Washer stopped at spin cycle, water still in tub and only the light on is spin green light, lid lock is off and can open lid.
Check codes and came back with actuator issue.
Replaced actuator didn't resolve problem.
Was going to change lid lock next, but ran the delicate cycle and it went thru the full cycle. Tried again on regular and casual cycle still have problem. Would the lid lock work properly on some cycles but not all? Any other places to look?
  • Curious00
  • Vance R
Not usually, run a calibration to clear error codes. Then run a cycle to see what codes comeback. Also check the drive pulley to see if it is loose.
Did a recalibration, then a wash. Goes to spin cycle, but never drains then lid lock unlocks and tub is full of water. Checked codes got F9 E1. Seems to be drain problem, but if you change cycle to drain/spin it drains perfectly and finishes cycle. So, during regular wash its not getting instruction to drain during spin cycle and then its timing out.
