Wolf 48" Range/Oven Burner Base
I need to replace the burner base in one of the oven compartments (24" side) but I'm having a difficult time locating the part number for the burner.  Here is the Range details, Wolf Model #PS48GBK-1, Serial #11020279.  I believe it was manufactured between 2000 and 2001.  I've tried to find a Wolf Parts List but I've been unsuccessful.  If anyone can provide me with the Burner Base part number, I would certainly appreciate it.
Thank you
  • ECtoFix
  • Mjarosik
Not sure what you mean by a burner base, but that's neither here nor there.
I did some research and appears Wolf  only made the PS series of ranges for one year:
In 2000, Wolf was acquired by Sub-Zero.  So they were likely going through a transitional period soon thereafter.
Sub-Zero/ Wolf's website isn't much help otherwise, but ELSEWHERE, I did find an excerpt from a service manual providing a cross-reference from old model numbers to new ones:
The cross-reference lists R484CG as the new model number for the PS48GBK (lacking the -1).  The R Series ranges were made from 2002 to 2014:
There ARE parts diagrams for the R series available from other sources on-line.  I found this downloadable copy for an R48 Series range:
In that manual, there are MANY references to parts having differing part numbers based upon the range's serial number (again, hinting at a transitional period of their product line).  There isn't much clarity offered about that.  Additionally, the manual makes absolutely NO mention of any correlations between the newer R Series units to the older PS Series.
I wrote a boatload of stuff here which might just lead to more confusion and uncertainty about what part number you need to order.  At any rate, perhaps you can identify the exact part you need BY ITEM NUMBER from the exploded view in that parts list, then call Wolf directly (with model/SerNo handy) and tell them what it is you need.  Their phone number is 800-222-7820.
DISCLAIMER:
I'm a commercial appliance technician, NOT residential.  I have FAR better luck gaining information on commercial stuff.
Perhaps one of the residential appliance folks can chime in with their greater knowledge/experience.
My bad.  Bad link for the model cross-reference didn't work. So do a search for-
Wolf Appliance Technical Service Manual, Part #803331
With that, access to the PDF will be available.
