Kitchenaid KODE500ESS00 oven not keeping temperature
Hello, I have a Kitchenaid oven that is not getting hot enough. I just changed both temperature sensors about 1 year ago, and that fixed the problem, for a while. Now, it is bad again. I need to know if I should fix it, or replace it. It is only about 4 years old!
Jerry
  • jkmhb
  • Josh Smith
the Sensors were W10859573 Whirlpool Range Oven Temperature Sensor.
Have you tested the sensors you installed last time? Maybe they failed? Do you run self clean cycles?
