Manufacturer: whirlpool
Type of Appliance: dryer
Model Number: wt87882
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): no
this model number doesn't show up on parts sites, but i have the dryer tag picture, it's clearly WT87882, built in 2004 or 1992, need parts manual (noisy dryer)
  • Son of Samurai
  • igloo
Hmm... if that really is the correct model number, then I'm not able to find anything for this one. Nothing pulls up for it at Whirlpool's site.
Just for the record, it's a top screen Canadian built model from 1992 with the element in the back, takes 349241 rollers and 341241 belt and WP691366 idler pulley, 3388235 motor. Forgot to look for the tech sheet while there. Unique parts are the 341165 drum light lens on the back bulkhead and the old 3 wire door switch w10820036 with pink w/red,  dark blue and  a white wire (to help match future wiring sheet). Closest model by parts from same year I found was the KEYE860WWH1. Not sure if the wiring matches.
Well, here's the schematic for KEYE860WWH1 in case it helps:
