Maytag washer LSE7806ACQ starts draining but then stops
I have a Maytag washer which starts draining water out then the water stops coming out of the drain and the machine keeps running. There is no kink in the hose there seems to be a small amount of water which appears on the floor in front of the machine.
  • Replies 1
  • Vance R
  • rfhjr
Remove the front panel of the washer. Then watch the pump during drain cycle. Look for leaks during drain cycle. If nothing is seen on top of the frame the machine will need to be tipped backward to look underneath.
