GE JVM1750SMC02 over the range microwave help
Just trying to do a diagnosis on whether its a capacitor or magnetron/diode.  I have 120v coming from my mother board and when i start the microwave the 120v stays as 120v and doesn't drop.  I have all functions such as light, turn table turns, appliance "hums" but i have no heat.
Just trying to whittle things down before i either buy a new one, or try and salvage this old one.  Door switches were replaced about 2 years ago.  This unit has lasted 12 years and wife likes it and would prefer to keep if it's cheap enough to diagnose
thanks in advance
  • caddylover
  • Vance R
  • DJJoshyBeats
Posted Images
DJJoshyBeats
Two things you can check before getting into the high voltage stuff (magnetron, capacitor, etc) would be those door switches and the fan motor. I know you said the door switches were replaced but it’s worth checking those for continuity. If you have the wiring diagram then you can check those switches with a multimeter. One of them will have opposite value of the other two (it will be open when the others are closed).
I tried to look up your model and couldn’t find if it had a circulation fan. But if it does then if that fan isn’t working it won’t be able to move the hot air into the cabinet. Also I attached a picture of a typical ge thermostat. Check those for continuity too.
Check to see if 120 vac is getting to the HV transformer. If that is good check amp draw into the HV transformer. Let us know the results.
  • 2 weeks later...
i did by a new LG but kept this older one as a project / extra for downstairs bar area.   i will get to it and post results.  sorry for the late reply and thank you for your advice!
