Manufacturer: Kenmore
Type of Appliance: Dishwasher
Model Number: 66514715N710
Thanks for the help!
Uploading tech sheet and waiting on approval:
Thanks Captain!
  • 4 months later...
Good morning,
I am doing my first dishwasher call and the model # is 665.14753N510. Is this the correct tech sheet for this model? Also, I noticed that the actual model # is no where on the tech sheet on the Assembly # (W10914074). Is this common? And in the future, without the model # posted on the tech sheet, how do I remember or know that this tech sheet corresponds to specific Kenmore/Whirlpool dishwashers. I know I'm probably reeking with the stinch of "rookie" right now but I just want to make sure I'm doing the right thing and learning as I go.
Thanks in advance.
It is always best to start your own post first of all and that is not the correct tech sheet for your Model. The correct tech sheet is W10750900 and that can be found in the download section. There will be no Model number on the tech sheet as there are a lot of models that cross over to the same tech sheet number. In this case to find the correct tech sheet you would go to Sears Parts and found the tech sheet number and come back here and search for it in the download section. Also if you want one you can just ask for it and someone will post it for you.
Edited by Captain Dunsel
  • Like 2
  • Thanks 1
Thank you so much Captain Dunsel!
