Viking gas range 4 burner & grill, gas oven & broiler: Oven ignitors need replacing every 5 yrs or so, but otherwise no problems with this stove.  Ignitors were on the way out again, but oven would still function with longer pre-heat time and typical sputtering.  One night the pre-heat indicator light came on as usual and oven started up, but when I checked later the pre-heat indicator light was out and the oven had completely stopped working.
I have since replaced both ignitors and bake burners and the dual oven/broiler thermostat switch.  Neither oven ignitor glows at all when the oven switch is on.  There is continuity in both new ignitors and adequate resistance.  Both the new and old switch have continuity for both bake and broil -- the broiler works with both the old and new switch, but the oven does not work with either switch.  A clamp meter registers power in the broiler wires, but no power in the oven wires when switch is on bake.  The pre-heat indicator light comes on when the broiler lights, but not when the oven switch is turned on.
The gas inlet valve (PB010084) also has continuity and so I have not replaced it.  Can the gas inlet valve fail even if there is continuity and is replacing it the next step?
Any thoughts? Thanks.
Wiring diagram at:
https://docs.google.com/document/d/1qtEhd1d7c6cVsFGUeAHsdP9XXeK2KR0X6ufi_2HbY54/edit?usp=sharing
  • Replies 0
  • spike1
