Manufacturer: GE
Type of Appliance: United Stack Laundry Center
Model Number: GUD27EESN0WW
Hi,
This unit is a bit different then the usual GE stack you see everywhere. The only real big difference is from my understanding it's Energy Star rated. Main thing I can say, and need a diagram etc for, is it has an electronic dryer control. Similar to their washer control system, apposed to an electro mechanical timer control. Bonus item is the issue I'm having is 2 brand new units at the same apt have had the same problem where the dryer motor will come on a few secs and then shut off. After a few attempts to start it will not start back up at all for a good while. Thanks for whatever help I can get on this in advance!
Edited by SbyApps
Here you go:
I should have joined Appliantology a LONG time ago!
Thank you very much!!!!!!!!!!!!!
