Manufacturer: kenmore
Type of Appliance: washer
Model Number: 796.4147221
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
Got an te error code. on sears parts direct there is no thermistor listed. I need the parts list with parts numbers.  I assume it is the same diagnostic as the other LG front load washers. However no thermistor is listed so I cannot  order replacement . I also need specs and location or thermistor.
Here is the service manual:
Check the resistance of the thermistor at the main board first to rule out broken wire in the harness.
Thermistor is in the heating element assembly
LG AEG33121501 Heater Assembly - AppliancePartsPros.com
Edited by Vance R
add parts info
  • Like 2
Thank you for the information.
I have repaired several of these with broken wires. I have actually installed quite a few thermistors too. My big problem is I don’t have the part number for the Thermistor. That’s why I need a Parts number for the thermistor on thos washer. It’s not listed on the Sears parts direct website parts list/diagram.
that’s the information I’m really looking for. Thank you Vance if you know that part number and if you could please provide that for me that would be awesome.
The Thermistor in the heater Are two different parts.
Edited by MsAnn
All i can find is the assembly, maybe someone has the number for the thermitor.
Same for me. So if anyone knows the part number for the thermistor on this particular washer. I would appreciate that information thank you
