    • 26 April 2025 02:00 PM Until 03:00 PM
      When: Saturday, April 26 @10:00 AM Eastern Time.
Manufacturer: LG
Type of Appliance: Dryer
Model Number: DLE4870W
Can’t find anything on this. Unit is giving a P5 error code after running a load of clothes and then needs to be unplugged and plugged in again to run another.  I have checked all wiring from the outlet to the unit and, other than the ground wire not being attached to the frame I found nothing outside of normal.  My suspicion is that it is a relay in the board that is going bad but I would like to have a manual to troubleshoot thoroughly.  Thank you.
  • StadGeor3
  • Captain Dunsel
  • Richie Mac
You should be able to use this:
  • Like 2
Thanks Captain!!!!
  • 4 years later...
Needed this, thanks Cap!
