consumer complaints that clothes are wet at end of cycle . no water in tub spins and drains fine.I do remember  whirlpool having a problem with water spraying in when cycle is done.but i dont remember what switch was causing the problem?Ithink this washer has same problem.
  • montrue
  • johntech
  • Scottekarate
Any error codes? Check suspension rods. Push down on the tub and let go quickly. If the tub bounces like a bobble head then replace the suspension rods.
Definitely check the error codes. Look for speed sensor errors or motor not reaching target RPMs.  I replace lots of shifters on these units. Follow the directions in the tech sheet, don't just guess.
If you need something more specific, let us know.
