Manufacturer: Kenmore / Whirlpool
Type of Appliance: washer
Model Number: 110.25902400
Can't find any info for pre diagnosis if this is a DD or VWM or what, keep getting conflicting info. Manual would help.
This is the tech sheet number that I can’t get to come up anywhere 8539562. Go to servicematters Limited Access. Click on it. Put your model number in where it says part number and then click on Parts list. https://servicematters.com/en_US
It is a DD Model: At least you will have the parts list!
  • Thanks 1
Thanks. Nothing shows up. But right now I'm assuming it's hopefully the same model as the closest model I could find which is 11025864400 . I'll have to photograph the tech sheet if still there when I get there to blast though the Kenmore information blockade! 😉
EDIT: got the parts list from servicematters. THANKS
Edited by igloo
Yeah you had to use the period in the Model number! 110.25902400
Quote
Managed to match the wiring sheet number from the parts manual to other 5 models finally finding this corresponding link to wiring sheet
for future reference, the above tech sheet works with these models
110.24932201 white
110.24934201 bisque
110.24902201 white
110.24904201 bisque
110.24922201 white
110.24924201 bisque
110.25862400 white
110.25864400 bisque
110.24892300 white
110.24894300 bisque
110.25902400 white
The actual tech sheet on the machine was a bit different with the lid switch wired in a different place for example. So uploading the pdf format of the photo of it titled  Kenmore-DD-washer-110.25902400-tech-sheet.pdf
Thanks, @igloo!
