GE JKP90BM2BB dual Oven / Microwave Primary Interlock and
I have a GE Combo Oven Microwave Range. On the microwave, I had to replace the Primary Interlock Switch. Outside of the faulty switch, I have used this Microwave for 10 years not knowing of any other issues.
As I connected the prewired plastic harness back on the new Primary switch, I noticed a difference in how it was wired (see link to harness - link 1) compared to the technical data sheet wiring diagram (see link of diagram - link 2).
Link 1 - https://drive.google.com/file/d/1bWlPL86K6URfdMPl8oxPkxWo1uQXAcrk/view?usp=sharing
Link 2 - https://drive.google.com/file/d/1OIjk6ObeUy33Nr6FU4RajHyasTyFHCNF/view?usp=sharing
If I understand correctly, according to the diagram (link 2), the Yellow wire (Y16) and White wire (W6) should connect to Primary common prong; and the two white wires W18 and W7 should connect to the Primary N.O. prong. Yet the plastic harness in link 1 is already prewired opposite of the diagram where the Yellow (Y16) and White (W6) are connected to the Primary N.O. prong, hence the White W18 and W7 are connected to the Primary common. I also researched and found that the Primary N.O. white wire W18 should connect to the Interlock Monitor Switch common (Primary N.O. to Monitor common).  Is this okay or has the plastic harness been wired incorrectly?
And if okay where should the W18 wire from the Primary connect on the Interlock Monitor Switch, common or N.C.? Again per the diagram (Link 2), W18 connects from Primary N.O. to Monitor common.
Because my harness is already prewired opposite of the diagram, should W18 now connect from the Primary Common N.O. to the Monitor P.C., or should I still connect to Monitor common?
Or is there danger for me to rewire the plastic harness per the diagram?
  • Replies 0
  • cjghou
