Click here to take the quiz.
This is a double door frig.  Left and right open doors.
2 weeks ago.  My drain plug was iced out and building at my bottom of the inside wall.   I used hot water to pour only at the drain hole and use shower towel to catch water.  The remainder water dissolved the bottom ice cube.  After the plug was cleared, the My frig was not starting up. All the lights were on, but the front ice/main temperature panel were dark.  The ice maker worked.  I disconnected the power source and traced to the power line and disconnected the plug and reconnected on the back opposite the compressor.  The frig turn back alive.
2nd problem, the ice crusher only spitted out crushed ice, so I disconnected the power.   I dissembled the ice cube crush/whole regulator and add oil to it.  It was iced up.  The regulator works now but frig wont buzz or power up.  😢
  • Replies 0
  • edcmaak11
