GUD27ESSJ1WW. Let me start out by saying I'm not a big fan of the new GE's... This laundry center is at a huge student housing Apt. and the maintenace guy contacted me syaing he initially got a complaint about a drain and/or spin issue. He said the "pump was clear" so he went ahead and installed the drive motor (his best guess). After that the unit was frozen with lights flashing.
I came out and reset the unit via key dance and flipped breaker. Controls were unfrozen and I got it into spin, and then started a normal cycle before I left--evrything seemed good, however he called the next day to say it was filling and agitating but would not go into rinse or spin.
The lid locked and went into spin when I was there so I dont suspect the lid lock. HOWEVER, I noticed half of the plastic body for the pulley on the underside of the motor was broken off and he said he broke it installing the motor. I noticed a little bit of noise, but nothing major (but Im not really familiar with these units) and told him to keep an eye on it.
Do you think the problem is the motor?
Jared
Speed sensor likely not attached correctly if he broke pulley.
Pull errors. Likely blocked motor error.
You would be if you ever worked on the current Whirlpool and Frigidaire laundry centers!
  • Like 2
Thanks guys. Ya, speed sensor damage sounds most likely... Ed: are you able to point me to how to access service mode? I couldnt find a tech sheet on unit.
Even whirlpool huh?! A friend of mine told me yesterday did at least start making their cleanouts accessible on their frontloaders now. It's supposed to be in the storage drawer...
Also, is the speed sensor in the pulley? Or would I have to replace whole motor assy
I was talking about laundry centers.
Mounts on bottom of motor between motor and pulley. I’ll try to find part number...
Thanks Ed! Much appreciated!
