rost/ice on only one upright freezer shelf - Kenmore 21501
whitedavidp
I was given a Kenmore Model 215O1, 5.0 cu. ft. capacity, upright freezer used in 2017. It has 2 shelves that both appear to have coolant being circulated through them. It has been in service until a few days ago when I emptied it to manually defrost the ice build up. I noticed then that only the upper of the two shelves had any ice build up. The lower shelf was cold to the touch but no ice. I went ahead and defrosted and re-started the unit. Nothing perishable inside it yet - only blue ice blocks. After running this way for a couple days, I can see frost forming on the upper shelf only. See the two red boxes in this photo. This is consistent with pre-defrosting but is disconcerting to me. Is this to be expected? If not, what - if anything - can be done? Thanks!
  • whitedavidp
  • evaappliance
is the temp about 0 degrees ?  if so it is not uncomon for the top shelf to frost over way faster, if the temp is up in the teens , then you have a system issue and it probley would not be worth fixing
Edited by evaappliance
whitedavidp
Yes, it gets down to 0 degrees no problem. And have not had issues with items not being solid and cold. But it seems quite odd that the lower shelf seems to produce no ice/frost. I don't want to have a breakdown since I have valuable salmon in there among other things. Hmmm.
Thanks!
The Freon comes into top shelf first, so it shows up way quicker on it. If it is getting down to 0 it is doubtful that you have an issue.   Not impossible but doubtful
