LG WT7250CW - Loud Rattling Noise On Spin Cycle, Water Leaking Underneath
bobbydigital
Hello All,
Today my LG washing machine started acting weird. During the spin cycle I could hear a loud rattling sound. As if coins are rattling around the machine. It only occurs on the spin cycle. Also, I noticed water was leaking from the bottom of the machine.
I've been researching this issue and I have stumbled upon a post that said this was most likely an issue with the tub seal and bearings.
Anyone have any knowledge of an issue similar to mine with the LG WT7250CW? Note, this washer is only 2yrs old.
Also, any guesstimate on what a repair build would look like? I tried researching TUB SEAL and Bearing Kit in the parts section of several online part stores and nothing came up for this model.
Thank you all for your time and responses.
  • Replies 1
  • Vance R
  • bobbydigital
Try clutch assembly, it is a housing with bearings and the main shaft.
