My AC condenser fan is not working. I just tried replacing the run capacitor and start capacitor since it's an easy/cheap place to start, but that didn't fix it. The fan will run, but then stops after 5-10 minutes. It won't start again unless I let it sit for long enough. It will start on it's own. I'm also questioning if I got the correct run capacitor. Old one says 5/45uF +5% 350/370v (see attached pic). The one I replaced it with is 45/5 MFD 370/440v. It's my understanding one rated for a higher voltage should be fine. I'm unsure of the 4/45uf vs 45/5 MFD. Everything I could find is 45/5 (not 5/45). This is what I got as a replacement one: https://www.amazon.com/gp/product/B0753YGNGB/.
Assuming the capacitor is fine, what next? Fan motor replacement?
  • Replies 1
  • Vance R
  • Jeremy S
Posted Images
As long as you hooked up the new capacitor correctly the motor would be the next step.
