Thermador Professional PRO-HARMONY PRG366GH/08 - Want help troubleshooting
We got this oven in 2011.
First, the broiler stopped working consistently.  Heating up the oven first worked sometimes.
Now the oven isn't igniting consistently and when it does light, it doesn't consistently hold a steady temp.  Do these 2 things suggest both Ignitors need replacing?... is that odd that both would fail so close together?
I've seen LED lights flash... Last night, I put it on CONV. Bake and got the lights to flash.  OVEN ON - 5 times; PREHEATING - 5 times.  I can't make the lights flash now.  How can I put the oven into test mode?  Assuming this is the only fault code, is this Error 55 meaning the Selector Switch needs to be replaced?  Someone in our family is guilty of turning Bake off, but not the temp. dial.  or temp. off but not Bake...Did that mess it up?
What are the symptoms of a Selector Switch failure?
Thanks, in advance, for any help!
~Pamela, former massage therapist..
  • Replies 0
  • Pamelucky
