Electric Dryer, Electrical Buzzing Sound (with video) - Samsung Dryer DV218AEW/XAA
Help!
Recently my Samsung Samsung Dryer DV218AEW/XAA Stack-able Electric Dryer is making an electrical buzzing sound. I would like to fix it myself if possible, but will call out a repair technician if necessary. Any advice would be appreciated!
Link to the model on Samsung Website (Note: Electric, not gas): https://www.samsung.com/ca/support/model/DV218AEW/XAC/
Link to Video of the Sound:
https://youtu.be/axW32oJAlmU
https://youtu.be/mlQaCsAQF1E
  • Budget Appliance Repair
  • 16345Ed
  • thefdo
Does not sound electrical to me. Needs disassembled, inspected and cleaned. I’d be suspecting debris in blower.
But belt, idler and rollers should be checked.
Sounds very similar to a Samsung dryer I worked on a couple months ago.
It was the idler spring vibrating for some reason - to fix it I lubed both ends of the spring hooks so they can't grip to the the metal and setup a vibration of the spring.   I also wrapped the spring coil with a piece of duct tape.
I would have preferred to use a piece of heat shrink tubing on the spring but didn't have any so went with the duct tape.  The lube on both spring hooks alone may have solved the problem.
I think I also remember seeing a post somewhere in this forum a few months back where they had to do something similar to stop a weird vibration noise.
