Whirlpool GSF26c4exb02 icemaker auger not working
I recently replaced the cam assembly on the freezer door. After reassembly and threading the wires and tubing through the cam assembly, everything was good except the ice auger won't turn. I've confirmed that the ice dispenser opens, that the ice auger is not frozen (I ran warm water through it), that ice is being made and the optical sensor detects a full bin. I've also gone through the dispensing diagnostics on the electronic user interface (Steps 8 through 30). All check out OK. Any suggestions for a next step?
  • pubprof
  • Vance R
At the bottom of freezer door/ cabinet there is a 2 wire connector with a gray and blue wires. Unplug the connector and use a voltmeter set to dc volts on the connector that is attached to the cabinet. Push the lever for the ice dispenser to deispence ice, you should get 120 vdc.  If you get 120 vdc there is probably a broken wire in the door wire harness. If you don't get 120 vdc at the cabinet connector check on the mian board connector p3 pin 7 and 8.
  • 2 weeks later...
Vance - thanks! I'll check it out!
