Amana BB2OYIE Fridge does not cool. MFG number P1321314WB
motoxmuseum
The freezer has melted and the temperature in the fridge is climbing. Fan is running but where should I start troubleshooting?
  • Replies 15
  • motoxmuseum
    10
  • Vance R
  • 16345Ed
  • ABA Tech
motoxmuseum
Compressor is not running. Evaporator fan was running last night but it is now not running.
I pulled the leads off the compressor and checked for voltage. None found. There is no noise like the unit trying to start and then waiting to retry.
The fan that runs in the back of the freezer to push air into the fridge is not running either.
Paul
motoxmuseum
Thermostat in the freezer opens and closes.
Paul
The leads connected to the compressor is where the voltage is supplied, so you have to check voltage with the wires still connected.
motoxmuseum
I checked the voltage by pulling the leads off and checking on the leads. The terminal block on the compressor shields the contacts and it is a challenge to get a probe into make contact.
Model number appears wrong. Hard to provide specific info without knowing units design.
Edited by 16345Ed
motoxmuseum
BB20V1E - P1321314WB
I never did find the serial number plate so I had to work with a handwritten note in the user manual. The model number should be as noted in this post.
Paul
The evaporator fan motor, condenser fan motor and compressor are wired  in parellel. So if one part is running they all should be running.
motoxmuseum
None of them are running. So does this mean the ADC is not working.
motoxmuseum
When the fridge is plugged in you can hear a hum and then you can hear a relay open. (Click). Am I right in assuming the first part I should try to change out is the Start capacitor?
Or thermostat, need to check for voltage at the fan motors and compressor. If no voltage need to check the thermostat then the adc board.
motoxmuseum
The fans are running and the compressor tries to start, you hear a hum and then a click.
Take the start device off of the compressor, ohm the winding of the compressor. Shake the start device and if it sounds like loose gravel inside, replace the start device. You can check the run capacitor to make sure it is ok.
motoxmuseum
I measure the start capacitor and it is 15.7uF. Label says 15uF.
The start device sounds solid. No rattles or other noise.
The compressor windings are:
Top
        Pin A
Pin B       Pin C
Pin A - B: 4.9 Ohm
Pin B - 😄 7.6 Ohm
Pin C - A: 3.1 Ohm
Paul
motoxmuseum
Just now, motoxmuseum said:
😄 is Pin C
