Manufacturer: Bosch
Type of Appliance: refrigerator
Model Number: B25FT50SNS
I found one that covers B26ft70sns, but since i have never worked on a Bosch before, I dont know if i can use that manual.
  • Replies 8
  • Scott-afl
    5
  • Son of Samurai
  • Econo Appliance
That model number doesn't pull up anything for me. Can you double check that it's correct?
B26FT50SNS/01 direct from the model # sticker inside fresh food
That works -- here you go:
thanks
First Bosch I've ever worked on, complaint of no cooling in fresh, food.
Found a no defrost evaporator for fresh food compartment, but I also had -5° at freezer bottom, and 25°ish at the top, found the freezer fan is not running.
I forced the unit into defrost, and both heaters came on, but the ff heater was only on for 30 seconds, then shut off. I tested the (similar to LG) temp fuse/temp sensor, but this is all the service manual gives for specs of the temp fuse: AC250V , 10A , 77℃. I tested continuity and resistance and got OL, but i got similar readings for the freezer temp fuse/temp sensor.
However, part of the troubleshooting flowchart for the bad freezer fan says to test the temp fuse/temp sensor, and like i said, i got similar readings for both. So its possible both are bad but causing different problems.
Please note however, the fresh food evap fan motor did run, so i might also have one bad temp fuse/temp sensor and a bad main pcb.
how do i test these temp fuse/temp sensor assemblies?
@Scott-aflPlease post your question as a new topic in the Appliance Repair Tech Forum. The manual requests forum is exclusively for manual requests.
  • 1 year later...
Scott,
do you remember what happened on this one?   I have same exact issue.  Just ordered sensor and board....
according to my notes, I replaced the thermal fuse
