Kenmore Model 9751714 Dripping water from freezer into fridge area
I purchased this new in December 1996. The only repair I had to make is a new water inlet valve in August 2019.  A month or so ago I noticed pools of water on the bottom trays in the fridge. So far I have fooled with the temp/air settings and have placed a bowl to the left of center in the fridge to collect the water, which now freezes so I empty it every 3-4 weeks. My icemaker works well. Thanks for any information.
  • Slav
  • Josh Smith
  • Pochie
A full model number helps. I assume it's a 106.9751714?
The dripping water is probably a defrost water from the freezer Evaporator area. The defrost happens every 8-10 hours, and if the drain is clogged up, the water will drip down into the fresh food section.
Remove everything from the freezer and pour some warm/hot water under the Evaporator coil. If the water is not going down, clear the drain tube. The clog could actually be on the bottom behind the refrigerator near the compressor. Make sure the water easily flows down into the defrost pan by the compressor.
Probably a clogged drain line
