85A59ED6-D31F-42B0-B75E-9C522C9A7E4E.jpeg.918beddfec3fa9262405065417962663.jpegI am trying to figure it out and appreciate any help..
The picture you posted shows the problem. I bet that burnt wire has broken insulation and shorted to the cabinet an inch or so below where the picture cuts off.
Need new cord.
  • 2 months later...
On 7/6/2021 at 12:16 PM, 16345Ed said:
Need new cord.
I agree.  That burnt wire on the left may be causing this issue.
This was caused by a loose connection . It overheats the connection causing a greater amp draw.   It can also do a lot of damage to the motor.  I was told years ago from a factor rep on compressor's that the greatest cause of failure for compressor's was loose connections.  A motor is a motor weather it is in a washer , dryer or, compressor.
It is essential a high resistance connection .
Edited by WOOKIE
additional info
