MSStateDawg
Hi,
I have a GE GFE29HSDASS refrigerator which has two ice makers. Both are very slow making ice. They do make ice, just slowly.
I have the temp set to 0 and it generally stays at 10 or below according to the display. The water filter is relatively new and I have plenty of water pressure in my home.
Is this normal for this model? What are the first things to look for in this scenario?
Thanks.
  • J5*
  • 16345Ed
  • MSStateDawg
  • Meliisa
Most slow ice calls I go on are simply normal production.
from your owners manual.
The ice maker will produce seven cubes
per cycle approximately 100–130 cubes
in a 24-hour period, depending on freezer compartment temperature, room temperature, number of door openings and other use conditions.
Im amazed they state that quantity
are they small cubes ?
i know my ice trays will take 3-4hrs to freeze
That might be because of the filter of your refrigerator. You could check if its clear.
