was wondering if you guys could help me diagnose this sound
my washer is 5 years old and it stops sits for 5-10 minutes then drains the water and i have to restart it
when the washing machine is empty is runs fine, something going on with loaded laundry
  • Replies 8
  • star99fox
    6
  • sh2sh2
  • 16345Ed
Sounds like broken triunion. Big job.
the spider arm is good,
should this move this much? if it isnt supposed to could my suspension springs be the culprit here?
photo_2021-07-17_20-49-38.thumb.jpg.d10049616d1219ec8f3d28a71706fce7.jpg is this normal or should it be tighter?
That spring is fine, the noise ur hearing is the ball bearings in the tub balance ring
ok thanks so then that play in the tub in my second vid is normal?
im going to try a power inverter to see if it fixes my stopping issue i read somewhere that fixed it for some people who were getting a 3e2 error i ordered it and will be here Thursday so will wait and see
do i need to replace the balance ring or is it fine to leave it like that?
Yeah the noise sounds normal from what I can tell on video
  • 2 weeks later...
alright guys its fixed it was the power inverter turned out to be electronic problem in the end.
I guess i ended up learning a lot about these front load washers so not a total loss replacing the spider arm i guess.
thanks for all the advice and info
