Manufacturer: Haier (GE)
Type of Appliance: Washer dryer combo
Model Number: HLC1700AXS
Unit is throwing “FC” error, i believe its miscommunication error previous company had replace the main control board.  Looking for service manual to test the unit and any suggestion what the problem could be.  The unit will throw the error when the door is locked and during the cycle.  Will fill, drain and tumble for a second and throws error.  Since the door is lock, when the unit is turned on when the door is lock it will throw the error withought starting the cycle.  But if manually unlock and powered on the error won’t show.  So far those are the only obvious thing going on, lock i believe is working because when the door is open and started door error would show (different error).
  • candpappliance
  • Son of Samurai
Here you go:
Thank you
