Need Electrolux EW30EF65GSH oven control panel Ribbon Cable
Hi - while replacing a control board for my EW30EF65GSH Electrolux oven I damaged the ribbon cable from the control panel. Apparently this cannot be purchased separately, only with the $2000 Control panel (316538416)!
     I was getting the F14 Error codes and replaced both the control boards (316576410, 316576610) after trying to fix the ribbon cable but it still beeped with the error codes.
      I'd like to try replacing the $10.00 ribbon cable before throwing in the towel and purchasing a brand new oven, but not sure which one and where to get. I don't believe it's soldered into the control panel by the looks of it and I've seen this done with a fix on other boards.
     Thanks in advance for any advice
  • PeteAB
  • Terry Carmen
The control panel is both expensive and not available.
Ribbon cables are actually repairable and replaceable. There are a number of youtube videos showing the process.
My son uses these quite frequently at his work and tried fixing it but the oven still didn't work - may be a bigger issue after all.
  Thanks for the prompt reply!🍺
