Click here to take the quiz.
      6
SHXM63WS5N Bosch dishwasher door opens way too far / leaks / stops running
Hi everyone,
We just moved into a home with a Bosch SHXM63WS5N dishwasher.  Ever since we moved in, we noticed it leaks a tiny bit on the right front and stops mid cycle.  It stops sooner in the cycle if we put it to the 60 express cycle.  When it stops there is no error code.  Also, the door opens about 2" below level, so we need to be careful when rolling out the bottom rack.
I looked through the installation guide I found online but I don't see instructions on adjusting the door height.
Any advice would be appreciated.
  • blammo32
  • ABA Tech
It's not an error code per se, but there is a red light that faces the floor that flashes when it stops.  Thought that might help.
Sounds like the door pops open and the cycle pauses, probably related to the door opening too far. Inspect hinges and door panels, if they’re bent or warped replace as needed. This is where I would start.
Thank you, I will engage a professional to repair.
