Manufacturer: Whirlpool
Type of Appliance: Front load washer
Model Number: Mhw4300dw0
Trying to figure out if the drain pump is accessed through the rear or the front on this model. Thank you
Uploading service pointer and waiting on approval. Information from service pointer!
The drain pump assembly has been
relocated from the base of the washer
cabinet to the bottom of the tub. One of
the main benefits of mounting the pump assembly directly to the tub was sound reduction during the drain process.
Removal:
The drain pump assembly can be accessed from the back
of the washer. The pump is attached to the tub sump by
four (4) screws and the pump inlet seal (as indicated on the following page). The internal drain hose is secured to the pump outlet by a hose clamp.
  • Thanks 1
Thanks, Captain!
  • Thanks 1
