New Appliance Service Manual added: Whirlpool Washer Drain Pump Assembly Relocation Service Pointer
View File
Pub W10742057
Models:
MHW3000BG2 MHW3000BW2 MHW3100DW0 MHW4000BW2 MHW4100DW0 MHW4200BG2 MHW4200BW2 MHW4300DC0 MHW4300DW0 MHW5100DC0 MHW5100DW0 MHW5400DC0
MHW5400DW0 MHW6000AG1 MHW6000AG2 MHW6000AW1 MHW6000AW2 MHW7000AG1 MHW7000AG2 MHW7000AW1 MHW7000AW2 MHW7100DC0 MHW7100DW0 MHW8100DC0
MHW8100DW0 NFW5700BW1 NFW5800DW0 WFW70HEBW2 WFW72HEDW0 WFW80HEBC2 WFW80HEBW2 WFW81HEDW0 WFW82HEDW0 WFW83HEDCB0 WFW8640BC2 WFW8640BW2
WFW86HEBC2 WFW86HEBW2 WFW8740DC0 WFW8740DW0 WFW87HEDC0 WFW87HEDW0 WFW88HEAC1 WFW88HEAC2 WFW88HEAW1 WFW88HEAW2 WFW94HEAC1 WFW94HEAC2
WFW94HEAW1 WFW94HEAW2 WFW95HEDC0 WFW95HEDU0 WFW95HEDW0 WFW97HEDBD0 WFW97HEDC0 WFW97HEDU0 WFW97HEDW0
Does this indicate a production change, simply noting that they moved the pump, or are they saying that it can be moved during service to make drain quieter?
It's a different design; instead of a hose from the tub to the pump, the bump housing is attached directly to the tub.
IMO, the easiest way to access the pump is from the bottom of the machine.
So it's a production change and not a field service thing?
  • 2 months later...
Yeah pretty sure it’s a production change. I just replaced one of these pumps and it was mounted directly to the bottom of the drum with 4 screws that screw upwards. There is no rubber drain boot like you commonly see. @vee8power makes a good point that accessing this drain pump when it’s mounted on the bottom of the drum is easier from the bottom. There are 2 front screws and 2 back screws you’ll need to access. In the repair I did, there was a laundry counter above the washer so I ended up removing the front panel and the back panel to access the pump which worked fine. But trying from just the front panel would be hard to reach the 2 back screws. I didn’t know the bottom could come off but if I could I wouldn’t do it anyway because like I said the washer I worked on was under a laundry counter and I didn’t have room to tilt the washer and I wasn’t going to mess around with disconnecting hoses. I took pictures of the front and back when I was working on it. The first and third pictures are the front view. The second picture is the back view.
Edited by JulianFarley
Is the bottom panel removable?
