Lw1216er air conditioner will not run continually
I have an lg lw1216er that I am trying to get to run 24/7 regardless of inside temperature. Does anyone have a wiring diagram for this unit? How would I be able to make the relay for the compressor and fan switch on and stay on? Can I like jump the contacts somehow? I have a smart home that will turn the power on and off with a relay meant for it but idk what's what on the ac. I need to use it for a small room to get it to 65 degrees and it stops when it thinks it's 60 which is usually like 67. I have some temperature sensors that can deal with regulation of temperature but idk how to get a wiring diagram and what exactly to do when I do. Help would be appreciated. I tried sticking the sensor outside but it doesn't quite reach and i think the cold metal case is keeping it from staying on because it makes the sensor cold.
  • Replies 0
  • Jatgm1
