Manufacturer: Kenmore
Type of Appliance: Dishwasher
Model Number: 665.16798790
Dishwasher won't drain. Fills, washes, heated dry - but no drain.  This older unit has one motor for both wash and drain.  Would like schematic so I can see if timer is sending out good power to motor for drain cycle.
Thanks!
  • Replies 4
  • David54
  • igloo
This should help some, as your model's timer is also used by DU910XXX
thanks igloo !  This will help a lot.
How did you make the connection with the timers?  Amazing.
Timer or control board is one of the unique parts to only few specific models. Found timer for your model on Sears parts site, then used another site that shows which models use that part.
Cool Thanks.
