whirlpool gas range connection broken
  • Terry Carmen
  • Shira
  • thomasr89
Are you sure there isn't a push on terminal hiding in the end of the wire?
It should plug into the bake ignitor.
Yes, definitely check if there's still a terminal on there first. If that fails, you could put on a new one I suppose. Something like this: Amazon.com: Supco T1112C Quick Disconnect, High Temperature, 12-10 Gauge, 1/4" Female Tab (Pack of 100) : Industrial & Scientific
How to Crimp Wires - Basic Tips on Crimping - YouTube
https://youtu.be/wsbsATkDBxc
If you've never done electrical stuff before, I'd definitely read and watch around a bit first. :) Good luck!
