Manufacturer: KENMORE ELITE
Type of Appliance: WALL OVEN
Model Number: 790.48039800
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
If anyone can help find tech sheet for model # 790.48039800 and a sheet for the proper error codes for this wall oven I would really appreciate it. The error code is F95err
You're looking for tech sheet 318047439 and wiring sheet 318046262.
Couldn't find any. Maybe someone has it listed under tech sheet number only. The model 790.48033800 shares the same tech sheet and wiring.
This is what another frigidaire oven tech sheet says about error 95
It's from a 790.48353410 tech sheet on this site
F095 Motor Door Lock mechanism failure.
The Motor Door Lock does not stop
running or the Lock Switch sends an
invalid signal.
1. The problem can be caused by a faulty Lock Switch or by a defective oven relay board. If the Motor Door
Lock is always running (as if the relay controlling it is stuck closed) replace the oven relay board.
2. If the motor is not always running replace the Motor Lock Assembly.
Found the wiring sheet. Quality is not very good even after increasing to 300ppi. Won't bother converting to pdf and uploading in case a better quality version in the future gets rejected to avoid duplicates.
wire diagram pending approval:
opps mislabeled just the wiring diagram hopefully Son of Samurai can fix title.
All set, Vance. Thanks!
  • 2 weeks later...
