Kenmore series 70, 110.76722694 making rattling noise intermittently and not heating. Please help!
My dryer is rattling intermittently sounds like something is turning on and off when this is happening and no heat. Just wanted some advice what it may be. Thank you!
Unfortunately this can be tough to diagnose without being there. Many noises come from typical wear parts, belt, idler, drum roller. Once disassembled all parts need visually inspected.
Heating circuit needs tested as well.
Since it's a gas dryer, if the rattling noise started at the same time as NO HEAT then the most likely problem is failed gas valve coil kit - the noise would be the gas valve chattering when trying to open.
  • Like 2
Thank you I'll look into that.
