Speed Queen Commercial Front Load Washer Model # SFNBCFSP112TW01
Need to know how to replace the hose from the Tub to the pump, part # 800317
  • Paul Harrison
  • igloo
  • CrazyCarl
Posted Images
The hose has a hole in it, need to replace the hose!
Doubt there’s a video for that. Should be able to change it if you take the lower front panel off. Either that or you can take the back off usually and might be able to get to it. Looks like one side has a hose clamp and the other is molded to fit the hole in the tub
This is 800317
Speed_Queen_Frontload_Horizon_Softmount_
This is 800902
Check before ordering.  Parts manual shows both for your model depending if you have the drain pump (800317) or the gravity drain valve(800902).
Edited by igloo
added info
